Replacement for aging antec 900
20 Jun 2011
Hi all,
Currently running an aging Antec 900 case and would like to upgrade to something a bit newer. I have an atx board running a 2500k cpu with a large Noctua HD-D15 cooler.. Want to be able to run 2 x asus 280x and for it to have some decent cable management (currently a big mess of wires.)
PC is sat under my desk so I’m not bothered whether its windowed or has led fans as majority of the time its not seen.. Willing to spend upto about £100ish.
Any suggestions ?
I went from a 900 to an RV03 a few years back. Cooling's even better than the Antec, fans are quieter (hooked up to motherboard and controlled by Speedfan based on GPU temp), cabling's so much neater & easier and loads of room for components. I love the rotated setup and that my GPUs will never sag. The looks are definitely love or hate but nobody can fault the case's performance.
Other than that, I haven't used any other cases bigger than ITX so can't offer any advice or comparison, just throwing a left field suggestion out there. :)
