replacement for E6300
6 Jun 2011
EU...
i have a 65nm dual core E6300 currently. will the mobo support any 1066MHz FSB CPU, including the quad core ones? does it matter if i get a 45nm one?
the pc is some crappy prebuilt HP thing (i know i know, i was young) and i can't find any info on the mobo anywhere on teh interwebz.
Can you load up CPU-Z and see what it says about the motherboard? It should support newer CPUs but only with a BIOS update I would have thought.
it says it's a Cuba MS-7301
how would i go about updating the bios? can't find a website for it :(
i'm getting a new pc anyway (in bits this time) so it's not a big deal, i just though it'd be nice to upgrade this one a bit and use it as a home rig (my new one will be at uni with me)
Just found that too, looks like it should be useful as it enables overclocking but it isn't an official BIOS if that worries you. I would've thought that a Q6600 would be your best bet.
hmmm. not too keen on an unnoficial bios. at least, not now while this is the only pc i have. i might risk it after i've got my new pc up and running. cheers for the help guys
