Replacement for GTX 1060
27 May 2003
Sheep Country (Wales)
Need to upgrade my Nvidia GTX 1060 3GB, now that GPU stocks are better and I have some upgrade funds.
Price between £250 to £350. AMD or Nvidia.
Got to do 2k at least, doesn't matter about 4k because my eyesight is bad enough not to really be able to tell the difference. I am old, shoot me.
Rest of rig is :
AMD Ryzen 7 5800X Eight Core 4.7GHz (Socket AM4)​
MSI MAG X570 Tomahawk WiFi (AMD AM4) DDR4 X570 ATX Motherboard
Patriot Viper Steel 32GB (2x16GB) DDR4 PC4-28800C18 3600MHz Dual Channel Kit (PVS432G360C8K
Cheers.
Seems a toss up between a 6700 10gb or a 3060 12gb if I spend £350.
Really wondering if its worth spending that much, or where the best bang for buck is in the current GPU ranges.
FWIW, I too don't care about 4k. I also don't care about RT.
Which is why I've stuck with my 1080Ti. Can get them second-hand for about £250-280. Fast card for that kind of money, imho. Of course, if you are prepared to wait until next stock, then 3060Ti FE is a great option if you want new (as has been suggested.)
I'd say it was a 6600 at £249 (a touch weak at 1440p latest games though) or go straight for a 6700 at £350, dealers choice ;)
Both will be a good bump over the 1060 :)
This should help a little;
3060ti FE
This if you can stretch to the £369 + delivery and can wait until a restock happens and you are savvy enough to find where to buy it. It's the best FPS per £ you'll find outside the second hand market. Otherwise what the others are saying.
Either 3060ti FE (they drop on a competitors site) for £369 or i'd personally get a 6600 for £250 and then look to do a full upgrade next year (RDNA3 / RTX4000) as we're looking at the best performance jump in the history of :D
This for sure, if you don't want to stretch then get the 6600 and it should last you a few years. The 5800X/X570 are good for quite a while yet, and shouldn't bottleneck you anytime soon.
RX6700 or RTX3060ti would be my choice. Both about the same price and both about the same performance.
I have the RTX 3060ti FE and its a great card.
Same as, It should be around 20-25% faster than a 3060. The 3060 really needs to be sub £300 in the current market to make it worth considering.
Crazy how much of a jump over the 2060 it is, cheaper MSRP and still not good enough.. shines a light on the importance of competition.
I've had a 3060 Ti FE and at £369 it's a cracking card! Was consistently faster than my 2017 Titan Xp ( full fat version ) and handled many of my games at 4k without an issue especially with dlss.. 3060 Ti takes my vote.
