- 3 Aug 2012
Hello all,
I have an old (11 years) PC. In a previous life it was my gaming PC, now it's my work PC. Generally, it's fine and running W10 Pro.
Salient information:
Mobo: Asus P6T Deluxe V2 Intel X58 Chipset
CPU: i7 950 @ 3.06GHz 8 MB cache LGA1366
GPU: GTX295 1792MB 16X PCI Express (2 DVI Port, No HDMI Version)
I have two monitors, but want to increase that to three, and I'm not sure how to go about that.
The two existing monitors are both DVI connected, the third monitor I want to add is HDMI only. The configuration of the three monitors I would like is (left to right) 24" DVI | 32" HDMI | 24" DVI.
Is there a reasonably inexpensive GPU I can place in this Mobo that will achieve that?
Thanks
Thanks
