- 4 Oct 2011
- Newbury, UK
I am looking for a new card to replace my MSI 670 OC reference (this one http://www.overclockers.co.uk/showproduct.php?prodid=GX-164-MS&groupid=701&catid=1914&subcat=2294).
The card works perfectly but it gets extremely hot. It touched 80 degrees last night which is too hot for my liking. I have set a custom fan profile but the fan gets too loud as well (I am quite picky about stuff like this if you hadn't noticed).
I have two/three possibles in mind as it stands and I am not tied to any particular company.
Firstly is the EVGA 670 FTW. Yes it is also a reference but my understanding after reading around it is on a 680 PCB therefore is cooler due to it using the 680 reference cooler! Is this correct? Is there much point going from one reference to another?
Second option is this http://www.overclockers.co.uk/showproduct.php?prodid=GX-097-GI&groupid=701&catid=56&subcat=938. I don't really care for which company I have, I have no preference. As long as it will perform to my liking. Also the other option from AMD would be http://www.overclockers.co.uk/showproduct.php?prodid=GX-297-SP&groupid=701&catid=56&subcat=938
As for the rest of my system spec I am running a i5-3570K, 8GB 1600mhz Vengeance RAM on a MSI Z77 MPower board. I have a Seasonic X-850w PSU and this is all housed in a CM 690 II Advanced Nvidia Edition case with 4 x intake fans and 3 x exhaust fans.
Any suggestions would be appreciated.
