Replacement GPU Cooler
30 Jun 2009
Norwich
Ot of these http://www.overclockers.co.uk/productlist.php?&groupid=701&catid=57&subid=787&sortby=priceAsc which would you suggest to be the best option to replace the stock cooler on my 2 http://www.overclockers.co.uk/showproduct.php?prodid=GX-201-SP
I like the price of http://www.overclockers.co.uk/showproduct.php?prodid=HS-047-AK&groupid=701&catid=57&subcat=787 but someone stated problems he had with his.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-031-AR&groupid=701&catid=57&subcat=787 looks effective and sounds nice.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-057-AK also sounds easy to install.
Price isn't an issue at the moment as anything is better than wasting £190.00 on a 4890 2gb pre-order when I want to get a dx11 asap. Don't get me wrong I like the sapphire pre-order but I think it's pointless when dx11's are just round the corner.
Cheers for your help :)
I would say go for the Akasa AK-VC03-BLUV Vortexx but thats if its fits.
If I were you I would sell the pair & get a single card such as a 4890 or 275.
As you will get £60 ish each for them giving you £120 + the £20/30 on coolers so £150
And with £150 you could get a Sapphire ATI Radeon HD 4890 Vapor-X or as you said £190 on the 4890 2gb.
There will be very little difference cost wise & a big difference performance wise.
Just my 2 cents or pence :P
