- 30 Oct 2007
Hi. I have 2 GTX 470 Twin Frozr II graphics cards, running in SLI.
A while ago (about 3-4 months) one of the fans starting making noise when I first turned the computer on that day. I could rock the tower slightly a couple of times, and it would stop for the rest of the day, but then it would be the same the next morning when it was turned on again.
It has now gotten to the point where rocking the tower is not working, so I have to open the case up every morning and physically stop the fan moving a couple of times with my finger. After doing that a couple of times it usually shuts up.
So basically I want to find a replacement fan, one that doesn't require me to keep the shroud off, so a direct replacement if possible. Also I know a lot of people are going to be desperate to tell me all the expensive GPU coolers I could buy instead, but please try and constrain yourselves.
The fan is a Power Logic DC 12v 4 pin brushless fan Model PLD08010S12HH.
