I bought a macbook in january this year.
So far it has had a charger replaced due to a problem, after 2 weeks. The man at the apple shop said there was nothing wrong with it and sent me away.
2 weeks later, it was faulty again, and I had to have it replaced.
http://forums.overclockers.co.uk/showthread.php?t=17860267
then I had a problem with the internet on it. It would not connect to the router at all.
http://forums.overclockers.co.uk/showthread.php?t=17856382
then I had a problem with the cd slot, in that every disk i put in gets stuck and refuses to eject.
http://forums.overclockers.co.uk/showthread.php?t=17817692
then I have also had the discoloration problem.
http://forums.overclockers.co.uk/showthread.php?t=17859612
now tonight, literally in front of my eyes it cracked.
http://forums.overclockers.co.uk/showthread.php?t=17859506
Needless to say, after 3 months of using it, I am not happy at all with this. I know other people with older macbooks with no problems at all! Yet mine has had all these problems in this amount of time.
Do you think they would replace the macbook because of this?
