replacing case fans
Permabanned
4 Sep 2007
Newcastle upon tyne
sup guys.. after buying my watercooling set up i'm after replacing all my case fans with some better/matching fans questions is which ones?
i'm not to fussed about noise i would rather have high air pressure and good air flow. i have been looking for some noisebreakers XLP 120mm fans but cant find them in stock any where.
Hi m8, what about the good old indians > Apaches they meet both your requirements > high air pressure + good air flow + very silent. Don't forget your using two know, a lot of peeps use them for case fans.
I wouldnt spend the money on sharkoons as case fans, same for the apaches, both are excellent fans, but theyre a bit pricey, and the apaches in particular are better suited as cooler fans due to being PWM. Cant really beat yate loons on value, £5.00 ono, yet they shift a decent amount of air.
