Hi,
I am planning to replace our large and worn out decking next weekend. The decking I will be getting from the merchants is your typical pressure treated stuff which has a green tint to it. I would like the decking to appear as natural as possible, unlike the last one which was painted green. After reading this thread , it seems that oil gives better results than stains.
1, Will the green tint disappear once oiled?
2, Should I oil straight away or leave the decking to stand for a few weeks?
3, I am best using a brush for the oiling, or look into a a pad or sprayer?
4, Any other tips I should consider?
Many thanks
Mark
Many thanks
Mark
