- 10 Mar 2010
So i have decided that allow with a complete revamp of my non-existant cable management i have decided that i am going to replace all the fans, the 2 LED ones that come with the Case are pointless -the LED are not bright enough so i need :
Front Cooling: 140mm intake fan
Top Cooling: 140mm exhaust fan
Rear Cooling: 120mm exhaust fan
Side Cooling: 2 x 120mm intake fan
For the 120mm Fans i was looking at these : http://www.overclockers.co.uk/showproduct.php?prodid=FG-022-SY&groupid=701&catid=57&subcat=4
what connection are these? 3pin or 4pin? would using a converter to make it the other type reduce the quality at all?
However for the 2 140mm fans i cant seem to find anything good, what would you recommend? performance only! i dont care what they look like they are both hidden so just 2 quality 140mm fans
with this in mind i am looking for a proper good Fan Controller - it needs to be able to control 5 fans i would prefer something Black (to go with the case)
for a total price i am looking to spend about about £75, £20 will be taken by the 3 fans already selected so that leaves about £55, could go to £60 for the 2 x 140mm fans and the fan controller
what would you guys recommend?
