Replacing Fans With These?
okay cheers, i have decided my setup :
x2 http://www.overclockers.co.uk/showproduct.php?prodid=FG-006-SH&groupid=701&catid=57&subcat=4
x3 http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-SH&groupid=701&catid=57&subcat=4
http://www.overclockers.co.uk/showproduct.php?prodid=BB-001-ZA
total without delivery around £75, so about £85 with it - 2 of the items are out of stock but it still says delivery would be Thursday, that right? or would the thing that is in stock be delivered and rest once its in stock?
how good is the cooling with them?
i guess it would be different for each system
thanks for the suggestion but i think that i will stick with the 2000rpm models
sure they can be loud but when full blast isnt needed i can just tone it down a bit
cheers, though the fans Tiamat21 listed were good and good priced, i thinki getting the Sharkoon ones for like £3 each more but with upto 2000rpm would be better and would give me ability to wack it up should temps start to rise in games - but they wont be at full the whole time
if you go to pages 6 and 7 which are the noise and airflow charts there are a lot more fans listed than the ones in the review and the sharkoon 2000 is in there.
41.2dba and 87cfm so plenty of airflow up full blast :)
right i have decided that i am going to get the above, ordering today will fit tomorrow
will be a pain in the a** as i will have to remove everything but atleast them i can try and sort the mess of a cable system i have :)
wish me luck :)
will there be any problems connecting the fans to the fan controller?
the fans go directly into the controller and nothing else right? then just have the Fan controller connected to the PSU?
that sound right to everyone?
Yep, the 3 pin connectors on the fans will connect directly to the 3 pin connectors on the controller. Finally fitted my controller last night, just waiting on some braided fan cables coming so i can start using it.
Okay thanks, dam OCuk! you dont have the fan controller in stock - get it NOW! Dont You Want my hard earned money? :)
well seems its going to be another week before i can bloody get them,
what is the time limit for things to be delivered the next day/saturday?
as i know a company thats limit is like 11:00pm and they charge less for delivery!
