- 1 Aug 2012
- Stoke-On-Trent
Hey guys so after about 3 T.V's being replaced from Samsung and else where i've decided to go for another T.V/refund tomorrow.
Problem is i aren't sure what T.V fits my bill.
Big things are the following :
4K
HDR+Game mode at the same time
Low input lag
under £1500
I did originally have a LG 4k before the KS8000 but as soon as it detected a HDR source it wouldn't allow game mode to be used at the same time.
Had problems with the telly since day 1 but they have gotten worse over time, done everything from updating T.V Firmware, to manufacture reset, to calling Samsung and getting a thing where they manually do it using a pin.
Had numerous problems with the Tellys, Smart remote not working on the 3rd Telly, as the bluetooth is naffed on it, that's what the "Know how" guy said at least.
The youtube app would constantly glitch to where the videos would overlap each other a lot and you couldn't actually click on the correct video.
When a Nintendo switch was plugged in to the dock without the system being attached to the dock it would constantly switch HDMI automatically and wouldn't stop doing it.
The volume got stuck on the T.V at 16 vol and you can't turn it up or down anymore but all the other buttons work on the standard remote bar the mute and vol up and down.
Would randomly turn it self off mid blu ray/game (No the auto sleep setting wasn't on or whatever it's called)
Had nightmares with the telly and i don't want a 4th one. I can have either a refund or a exchange, now i do want another T.V i just can't find any that check all the boxes for me.
Any recommendations as i really don't want to go over my original price bracket of £1500
Thanks!
4K
Low input lag
under £1500
Thanks!
