Replacing rear brake pads
18 Oct 2002
Stone, Staffordshire
Cars now on 57k miles and the rear pads are ready for their first replacement.
Alfa Dealer wants £184....what do you think of this price? Car is an 06 GT 1.9JTDm
Car is still under warranty and has FASH and I certainly don't have the time or inclination to DIY! If the price is too high what else should I consider, Kwik fit, nationwide, a.n.other?!
I live in Stone, Staffs and work in Warrington so either of these places are good for alternatives!
£184 for rear pads.....jesus!
are they carbon or ceramic or something? I'd phone some places like you've mentioned for quotes if you don't want to do it yourself. I'm not mechanic, but i'd have a go myself as they are easy to do.
Is that for just pads or does it include replacing the discs as well?
The pads will cost no more than £25+VAT from a motor factor and it's no more than an hours labour.
Take it to an independant garage - it should cost no more than £80 really.
hopefully it's discs too at that price.
They shouldn't need changing yet though if it's the 1st pad change?
So £140 for labour?
They are having your pants down. Pads on the rear take about 1hour max if it's your 1st go.
It's not a specialist job, any garage could do it an they'd probably charge you no more than 1hours labour.
Do you think it will effect the service history and therefore resale value if I don't get the Stealer to do them?
It would bother some people but equally others wouldn't care or wouldn't notice, personally I can't see it knocking that much off the sale price and if you have to have similar stuff done the cost of the Alfa Steeler will soon out weight the benefits of a full history. Just make sure you get some reciepts etc to show a potential purchaser that you did have it done and I'd probably go for a reputable indy garage rather than quick fit type places as some people have an aversion to them.
Only recently found this out but Honda will do a front or rear pad change for around 80 notes so 184 does sound like a complete rip-off.
Also I personally don't think that getting an indy to replace the pads would affect it's resale value? I mean you certainly don't get your tyres replaced by the main dealer (do you?) and that doesn't seem have a bearing on the resale price.
I don't know of any main dealers charging only £40/hour for labour (probably well over twice that in practice), though £140 is excessive.
Sorry, I should have said - I was reffering to independants. Not familiar with Alfa/Fiat - but I think my local Renault charge £56 an hour. But in practice they most likely quote 2 hours labour :p
Will having the pads changed at an indy affect his warranty if they're OE pads?
I seriously can't believe people pay £100 for a brake pad change. For a job like this, there is absolutely no reason to go to an Alfa Romeo independent/dealer. Just a nice independent garage will do it just fine.
Instead of making my own thread il post here
I will be changing my rear brake pads, and my front discs and pads. I have bought everything, then I read that apparantly when changing brakes I need new wheel bearings also. Can someone clarify whether it is when changing discs or pads i need new bearings?
NEVER heard of that one before. Did you hear it from the place that was supplying you with the discs & pads ....
nah i read it on a forum....something about you cant use the old bearing when changing brakes
Im as much as a mechanic as I am a brain surgeon, therefore I run to Ocuk
I have got front discs, pads, brake line, and rear pads. Take it I dont need anything else for them to be fitted?
Also I got quoted 225 for fitting all of that plus changing all my suspension springs for some eibach prolines. Is this a rip off? its with an independant garage
