Hi,
How would I go about getting a new garage side door? Its pictured below but both the door and the wooden support frame that clips onto the concrete prefab really need replacing. Needs a lock in both the door & frame as well.
Is this something you can buy pre-made, fairly easy DIY or something that's worth finding a carpenter for? Obviously keen for it to be secure/long lasting If anyone has any thoughts on costs for a carpenter that would be helpful.
Thanks!
Thanks!
