- 6 May 2010
My current system motherboard (MSI K8N Neo4) fan is about to fail, the geforce 7600gt fan sounds like its packing in too, and i feel like upgrading my system as i have some money to do so. I don't really play games anymore, but i may reinstall Simcity 4 or C&C possibly.. all i really use my computer for is browsing and some video editing. Part of the motive is also i wish to get Windows 7.. still using XP lol. Hopefully what i have in mind will last/meet my needs for the next 4-5 years. I'd appreciate all comments and help
I have an Aspire Discovery-X case, with 2 front Vantec Stealth fans and 1 rear 120mm one. The side fan is off. Nexus fan controller at the front.
Mobo - MSI K8N Neo4
CPU - AMD Athlon 64 3600 Dual Core + Zalman Fan
1 GB Ram
Seasonic PSU (can't remember the wattage)
Geforce 7600 GT
Audigy (original oldschool version
I would like to keep the case and fans obviously..
What im thinking:
Mobo: ASUS M4A79XTD Evo (Socket AM3) DDR3
CPU: AMD Phenom II x2 Dual Core 545 3Ghz AM3
RAM: Corsair Dominator XMS3 4Gb (2x2Gb) DDR3
HDD: Western Digital Caviar Green 1TB Sata II 64Mb
GPU: Asus Geforce 210 512mb
PSU: OCZ Stealth X-treme 500W
CPU Fan: Zalman CNPS9500 AM2
+a new optical drive as the old one is IDE.
My initial questions are.. will this combination work? Is the PSU wattage enough? Will the Zalman AM2 fan cover the AM3 chip? Will the original Audigy i have work in this setup/is it even worth it? Is this setup overkill?
Ideally i wouldn't like to be spending more than 500 on the hardware. Hopefully this has painted a sufficient picture for you to help me (noob) out
Thanks for you time, Simon
Mobo - MSI K8N Neo4
1 GB Ram
Geforce 7600 GT
)I would like to keep the case and fans obviously..
What im thinking:
