Requesting Help - Belkin wireless
9 Jan 2003
Cornwall
gah! I can't get my belkin wireless card working on my ubuntu laptop
Belkin Wireless N1 F5D8011
I need the ini from the windows driver but I can't get it to run in wine or extract.
does anyone know where I can find the ini or have a copy/advice for me on this?
once I've got the ini I figure I can run it via ndiswrapper?
Google seems to suggest that it may well be supported by the MadWifi Linux drivers.
Worth giving them a shot : http://madwifi-project.org/ Although this may only be for the older versions which used the Atheros chipset.
If that doesn't work, can you post the output of lspci & lsusb.
EDIT: Is your card V3? If so I think it will use the Ralink RT2800 chipset, in which case you want to try the Rt2x00 linux drivers from http://rt2x00.serialmonkey.com/ which is down at the moment i think, but should be in your distros repos.
V2011
03:00.0 Ethernet controller: Marvell Technology Group Ltd. 88W8361 [TopDog] 802.11n Wireless (rev 03)
is relevent line
ok so none of that works at all
going to install on windows machine and make sure it's ACTUALLY working.
