Res and pump layout
20 Sep 2011
local
I am using a separate pump and res in my build ,normally I would use a pump/res combo.
I know pump is supposed to be lower then res,but would I get away with it set up the way I have it now ?
Im not so sure,it looks like the pump is mounted with the inlet being vertical and the outlet horzontal,if you flip the pump onto its side it should be ok.
