Res running low.
9 Aug 2010
Uk
Judt opened my case to find that I my res level has gone down quite a bit. Now my question is should I just top up my res with new distilled water or should I empty and refill? Would just topping up my res be detramental to my loop?
I don't think/can't see any leaks as the system has been on 24/7 since I put the loop in about 6 months ago and hasn't gone boom yet. I think it is just down to my loop getting te last of the trapped air out. Though I will run another leak test tonight when I fill the res up.
I tend to find that barbs could become wet and not technically leak, so you wind up losing liquid through evaporation more than anything, since I switched to compression fittings, my res has only dropped less than a 1cm in just over 6-7 months. Just in case you are using barbs.
Thanks for the heads up but I'm also usingcompression fittings. I'll update once I get home and can take a close look atthe possible issue.
--UPDATE--
Filled res back up, though now the res is leaking from the bottom threads where the clear plastic meets the black plastic possibly over filled it. Opps
