resizing / - howto without reinstalling
22 Aug 2005
Clydebank
Hi all
What is the best way to fix my partition size issues.
This is my debian box, 2.6.32 .
Could I boot gparted on a live CD and resize my / to be bigger, and shrink my /home to give it the space ? Even though /home and / are not beside each other on the disk ?
Code:
Filesystem            Size  Used Avail Use% Mounted on
/dev/hda1             327M  278M   32M  90% /
tmpfs                 505M     0  505M   0% /lib/init/rw
udev                  501M  516K  501M   1% /dev
tmpfs                 505M     0  505M   0% /dev/shm
/dev/hda9             137G   41G   89G  32% /home
/dev/hda8             373M   11M  343M   3% /tmp
/dev/hda5             4.6G  3.2G  1.3G  73% /usr
/dev/hda6             2.8G  914M  1.8G  35% /var
/dev/sda1             1.4T  1.1T  291G  79% /mnt/data1
/dev/sdb1             459G  417G   37G  92% /mnt/500GB
/dev/sdc1             1.4T  784G  579G  58% /mnt/data2
/dev/sdd1             1.4T  1.1T  299G  79% /mnt/1500GB
Code:
Disk /dev/hda: 160.0 GB, 160041885696 bytes
255 heads, 63 sectors/track, 19457 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x000a16ec
   Device Boot      Start         End      Blocks   Id  System
/dev/hda1   *           1          43      345366   83  Linux
/dev/hda2              44       19457   155942955    5  Extended
/dev/hda5              44         651     4883728+  83  Linux
/dev/hda6             652        1016     2931831   83  Linux
/dev/hda7            1017        1346     2650693+  82  Linux swap / Solaris
/dev/hda8            1347        1395      393561   83  Linux
/dev/hda9            1396       19457   145082983+  83  Linux
