Resolution Help
1 Jul 2009
I'm using the Samsung T220 and the max resolution i can get working fine is 1280 x 1024. I have tried 1650 x 1050 and it cuts off the edges. I have read on some other forum that Samsung can sometimes mix the settings so it thinks the monitor is actually a T190 so if this is true how can I fix it?
Played with the settings and it finally worked. I had to set it to 1650 x 1050 then click the button on the side of the monitor to auto-resize.
