You should be able to check these codes on the Ross-Tech wiki no? Just googled the last code, which took me straight to the Wiki here: http://wiki.ross-tech.com/wiki/index.php/02432
Yes, but the explanations given are related to that unique fault code whereas I'm pretty sure what I have is one problem causing numerous fault codes. From what I can see there isn't any option to input multiple fault codes and find any link between them, and tbh I wouldn't expect there to be as that's far too complex.
