- 22 Jul 2012
- London
Hey there, as the title says, all of a sudden my PC has started taking it's time with shutting down and restarting.
The actual leaving the desktop shutdown part is normal, but once it gets to the point where it would normally completely power off the system, it hangs with all the fans still running and power still going to PCI slots (lights on soundcard still lit for example). The monitor will switch off as normal.
I then have to hold the PC's power button to switch it off completely.
When restarting, it'll do the above but with the exception that it'll take it's time to switch off then it'll wait for a few seconds before powering up again.
It also seems to take a little more time to reach the bios screen.
This started the other day after I installed a fan without touching anything else. I have since installed a new cooler which involved removing/reinstalling the mobo, so I know that everything is plugged in properly and all in order.
No new software has been installed, and virus scans come up clean.
System specs are in my sig and Win7 64 HP is running on the SSD if that helps
Cheers for any advice.
