- 3 Aug 2008
- Brighton
Hi Guys
Thought I would post up my results from my latest upgrade in case any one is considering a similar purchase.
Some of you will remember I was asking a few weeks back about the TRUE cpu cooler/heatsink from Thermaltake and asking which fan would be best?
So I lapped my cpu and the thermaltake TRUE so they were nice and flat and shiny!!
After reading lots of reviews on the TRUE vs the Asus slient Sq series I decided to go for the TRUE as it seemed people were shaving more degrees off their load temps when overclocking. I was then told that for performance the Delta fans were the best but very LOUD!
I threw caution to the wind and ordered one and the it arrived!
I'm not joking the DELTA fans are the loudest fans I have ever heard the noise is ridiculous and annoyed me instantly - seriously you can't live with one of these things in your pc! I always have music on or I am gaming with the volume up but the noise of the fan just pi**ed me off!
So I bought a Scythe Kama Meter and its lovely, its blue to match my Antec 900 case fans, its built really nicely and it allows me to run the DELTA between 1200 - 3500 RPM which is more than enough I can't recommend it more.
Any way on to the temp results. I was able to overclock my Q6600 to 3.6 with the intel stock cooler in my case due to the passive mos fets on my maximus formula board and the ambient temp in my case so I have included these temps as well!
Intel stock cooler
@ 2.4 - cpu 23-24degrees idle
@ 3.6 - cpu 33 degrees idle - 69 - 70 degrees under full load on prime
TRUE & DELTA
@ 2.4 - cpu 17 degrees idle
@ 3.6 - cpu 22 -24 degress idle - 41 degrees under full load on prime
I'm well chuffed thats nearly 30 degrees off my load temps!
This heatsink and fan combination really comes into its own under full load!
Highly recommended BUY THEM TODAY!!!
Still can't get over 3.6 but not becuase of temps, just stabilty
Intel stock cooler
TRUE & DELTA
