Try coretemp or something like that. Those temps sound a bit on the low side. In fact you are cooler than my water setup and my water is just above room temp at idle. I find it hard to believe that is your core temps. I personally use everest as it shows me all my temps, hdd's, nb, sb, etc etc.
High end air like the setup he has will give anything but a high end water setup a good run for his money at that clock...
water is not always better than air... very much depends on the setup these days
can run 40c across the cores at 3.6ghz load
