Hibernate instead of shutdown
I use my power button on my NZXT case to shut down. Can I just go into advance settings and change "shut down " to "hibernate" on the power button?
Will likely be in control centre, where you select the performance plan, and then edit the plan.I use my power button on my NZXT case to shut down. Can I just go into advance settings and change "shut down " to "hibernate" on the power button?
You should be able to control what the power button doesWill likely be in control centre, where you select the performance plan, and then edit the plan.
Yep in power settings, there's an option called something like "choose what power button does".
