I'm the process of building a retaining wall for my patio and I've just finished the concrete foundations and ready to move onto the breeze block walls. The intention is build the wall out of concrete breeze blocks and then render the visible blocks and paint it white. The wall will be circa 1m high and will have a small parapet.
I've been reading a lot on Paving Expert and came across the following guide for building a retaining wall.
http://www.pavingexpert.com/featur03.htm
I'll be installing a DPM as per the guide however do I really need drainage channels?
In terms of backfilling, you can see there's load of excavated soil/clay under the blue sheet and plenty of old slabs etc in garden, can I use this to build it up to the level I need, then lay the sub-base? I was hoping I can get away with compacting the soil as backfill as I go?
