- 26 Mar 2007
My willy is de-catted. No problems with smelly or sound. I've only done it because the existing catalytic converter is 17 years old and costs £300 to replace.
The car is also an old enough import that it doesn't actually need the cat for an MOT which is handy.
.Complete myth, no 4 cylinder NA engine needs backpressure.
My S2000 has a sharper throttle and sounds better with a decat.
Correct, when I had my Impreza it was MOT'd by a garage where I knew someone there who was a technician, and he said emissions were not checked on as it would have failed (they knew about the decat). Yes it's wrong but hey.
in my EXPERIENCE, ive seen where the ecu will trim back the fuel mixture further and further try and compensate. the fuel trim ends up out of spec and hence limp mode and CEL lights.
why do you think people bother to make up emulators or disable the secondary lambda function if its only role was to trigger a light?!
