Revell 1/48 Mosquito B MKIV
5 Feb 2006
Not sure if people are interested in a model build thread but I'll put this one up as its going to be for my Dad who is 80 in June.
The De Havilland DH.98 Mosquito is a British twin-engine shoulder-winged multi-role combat aircraft, introduced during the Second World War, unusual in that its frame is constructed mostly of wood. It was nicknamed The Wooden Wonder, or "Mossie". Lord Beaverbrook, Minister of Aircraft Production, nicknamed it "Freeman's Folly", alluding to Air Chief Marshal Sir Wilfred Freeman, who defended Geoffrey de Havilland and his design concept against orders to scrap the project. In 1941 it was one of the fastest operational aircraft in the world.
Originally conceived as an unarmed fast bomber, the Mosquito's use evolved during the war into many roles, including low to medium-altitude daytime tactical bomber, high-altitude night bomber, pathfinder, day or night fighter, fighter-bomber, intruder, maritime strike aircraft. It was also used by the British Overseas Airways Corporation (BOAC) as a fast transport to carry small, high-value cargoes to and from neutral countries through enemy-controlled airspace. The crew of two, pilot and navigator, sat side by side. A single passenger could ride in the aircraft's bomb bay when necessary.
The Mosquito FBVI was often flown in special raids, such as Operation Jericho – an attack on Amiens Prison in early 1944, and precision attacks against military intelligence, security and police facilities (such as Gestapo headquarters). On the 10th anniversary of the Nazis' seizure of power in 1943, a morning Mosquito attack knocked out the main Berlin broadcasting station while Hermann Göring was speaking, putting his speech off the air.
The Mosquito flew with the Royal Air Force (RAF) and other air forces in the European, Mediterranean and Italian theatres. The Mosquito was also operated by the RAF in the South East Asian theatre and by the Royal Australian Air Force (RAAF) based in the Halmaheras and Borneo during the Pacific War. During the 1950s, the RAF replaced the Mosquito with the jet-powered English Electric Canberra.
So made a start on the cockpit with the Eduard PE being fitted as per the instruction. Test fitting of the fuselage halves show the radios needed to be moved to allow the 2 halves and the canopy to fit properly.
Coloured PE was left off and the interior areas of the cockpit, bomb bay and U/C bays were primed with badgers white primer then painted with MRP-111, Interior-Grey Green.
The remaining PE was fitted and final assembly carried out with minimal test fitting and no real filler required.
UPDATE TWO
So, moving on, we have the upper surface lightened and mottled with some thinned XF-2 flat white.
Then the first camo colour, MRP's 115, Ocean grey. This was then masked off with white tack worms and masking tape.
Then the second colour was MRP's 110, Dark Green.
UPDATE THREE
The upper camo surfaces were masked off. References were helpful in determining the demarcation lines.
Then the undersides, bomb bay doors, undercarriage doors etc were painted with 2 coats of thinned XF-85, rubber Black and the a thinned XF-17, Sea Blue was used in panel centres. This all gave a good tonal variation to the night black that looks a little worn.
I also have a split in the top seam near the tail, probably caused by handling despite it being glued with extra thin and then CA glue. So that will need fixing and re-painting.
UPDATE FOUR
I started off with gently squeezing the rear fuselage to expose the crack more easily. Then I used a panel line scriber to then dig a trench over the crack. This crack was then filled with tamiya extra thin plastic glue and left to harden.
Then the remaining trench was filled with some medium viscosity CA glue. This then had baking soda applied to harden the CA glue.
The bead of CA glue was then sanded back and the area cleaned ready for re-painting.
love it - I wish I had the patience to complete as intricate a build as this. currently struggling to finish a King Tiger (which is rated as easy - yet I've still managed to break the tracks and glue my t-shirt to the desk!!)
UPDATE FIVE
The split seam has been repaired and re-painted.
Next was to mask off and paint the exhaust stacks in XF-84, Dark iron. Then some light rust pigments were rubbed over to weather accordingly.
Ultimately, this was to no avail as once the exhaust covers were on, the exhausts stacks could not be seen.
Then paint work was rubbed down with a polishing sponge,. cleaned and the decals applied. There are a few small spots of silvering to fix but next with a coat of sating varnish to seal the decals in.
UPDATE SIX
With the paint work and decals complete, another coat of satin varnish seals everything up.
Then it was a wash of Flory Models dark dirt wash on the camo on the upper surfaces and then a mix of dark dirt and gray on the underside night black surfaces.
UPDATE SEVEN
After cleaning up the wash, I started to get the undercarriage and doors fitted and bomb bay doors fitted.
Then the aerials were added and some ez-line used for the aerial wire.
Nearly finished.
Very different way to washing than I'm typically used to! Then again I tend to paint a very different type of mini.
Amazing how the washes bring everything together. Weathering is something I've been trying to practice and get my head around. Making a flat surface not flat, is an art in itself.
Great save on the seam line, looks like it never happened.
I really must get around to trying MRP as they appear to leave a fantastic finish. I've not been impressed by Vallejo Model Air, I'm really liking Mr Color, but I've seen and heard so many good things about MRP that I'd be daft not to give them a go.
