This was an excerpt from the minutes of the meeting I had with the planners and my architect in May 2014:
"2. Even though the proposed garage is the same size as the existing, because you are proposing a change to the layout, the new garage needs to meet more recent design criteria and LCC (Leeds City Council) want a 3m x 6m garage (ours is currently 2.76 x 5.57m). This means that we need to move the side wall out by about 300mm/12” towards your existing side fence (in turn you get a slightly larger master bedroom/ensuite overhead). (NB - The re-positioning of the side wall means the existing foundations will definitely not be fully reusable and so new strip footings would be required – therefore there is probably no point in paying an engineer to come out and check the footings prior to construction.) "
