*Review* Qpad MK-85 LED Pro Backlit Mechanical Gaming Keyboard - from Vortez.net
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Thanks to http://www.vortez.net for the following review. Big thanks to w3bbo for writing the review.
CLICK ME FOR THE FULL REVIEW
QPAD's previous mechanical gaming keyboard was very impressive but QPAD have not sat back to bask in the glory of the MK-80. Instead they have recently introduced the MK-85 Pro gaming keyboard; a top of the line product that on paper at least features everything you could want from a gaming keyboard. Backlit, programmable macro capability, mechanical switches, N-key rollover all backed up by a two year warranty. Apart from the macro capability, the MK-85 doesn't appear to have added much more to the MK-80 keyboard we reviewed HERE but there is more to this piece of hardware than meets the eye.
Conclusion
This keyboard has it all. If I was impressed with the typing ability and comfort of the MK-85 then I am astounded by its gaming abilities. Want macro programmability? Not a problem! 5 profiles? Sure. Adjustable backlighting? You got it. Perhaps the only thing missing from this keyboard is the ability to change the backlighting colour and an LCD screen. For less than the asking price of the MK-85 you could have these features in the Logitech G19, widely regarded as the pinnacle of gaming keyboards. The G19 however does not have mechanical keys and thus pales in comparison to the outright performance of the QPAD MK-85.
The MK-80 was a great looking keyboard of that there can be no doubts. The luxurious feel of the keyboard surround and backlit key set put most other keyboards in the shade (literally). However, there were two issues which prevented MK-80 from being our top mechanical keyboard - no macro functionality and the use of Cherry MX Blue keys. Guess what QPAD have gone and done? The MK-85 now has macro capability and has the much better (for gaming at least) Cherry MX red switches. With this in mind I'm going to be true to my word and put the MK-85 in number one spot in the hotly contested mechanical gaming keyboard market. It is a deserved winner of not only our esteemed Platinum award but also gets the rarely given Elite award simply for being the very best there is to offer in this segment, regardless of its high asking price. If the girl from the L’Oreal advert was worth it, then the QPAD MK-85 most certainly is.
Our previous best mechanical keyboard, the Tt-eSports GMEKA has the stiffer Cherry MX Black keys which may appeal to some but if you get the chance you really should try the Cherry MX-red keys. They are much better for typing with and while the Corsair K60 also made use of Cherry MX Red keys, it fell short in terms of comfort due to not having a full range wrist rest. The SteelSeries 7G while impressing with its size lacks the refined feel of the QPAD range. So that just leaves the Ozone Strike and QPAD's own MK-80. The Ozone Strike is a basic no frills gaming keyboard, much the same as the SteelSeries and QPAD's own MK-50 keyboard and while that is no bad thing, they cannot really be compared to the MK-85 as the MK-85 offers more frills, useful frills that is. So it's the old vs. new; MK-80 vs MK-85.
Pros
+ Cherry MX Red Mechanical Switches
+ Perfect for gaming/very comfortable for typing
+ USB & Audio Hub
+ Expensive plastics
+ Optional replacement keys
+ Adjustable backlight
+ Macro capability
+ Full NKRO through a single USB
Cons
- Expensive
- No Key lock LED brightness adjustment
index.php
index.php
Not worth the money over the 80 imo especially as the only real difference is the rollover thing. If i was buying now would still buy the MK80 again, fantastic board.
Macro capability? Cherry Red switches? Surely those features are more prominent than NKRO?
I do agree though, the MK-80 is great - especially if you prefer tactile feedback.
The Filco M-2 uses Cherry brown iirc (m1 uses blue) so it is aimed more towards typing than gaming. Browns have light tactile feedback, blues are a little heavier than browns and also have tactile whereas reds are linear.
The MK-85 doesn't need a PS2 to do full NKRO so if you don't have a PS2 port and NKRO is important to you then the MK-85 is the way to go. From a gaming perspective, the MK-85 is the best keyboard bar none. If however you do a lot of typing, you may prefer the MX-brown key switches. IF you do lots of both then go for either red or blue. If you are an out and out gamer then perhaps blacks may suit you more.
I'll try and get hold of a Filco and see how it stacks up.
I have one with brown switches and it is a fantastic keyboard! The only thing I don't like about this keyboard is the fact that you can't use it for BIOS operations.
Why not? Are you sure the BIOS is configured to use USB?
It worked fine on my USB Saitek Eclipse II. I just assumed that it needed a specific driver for NKRO to work that wasn't a standard one that BIOS uses.
I'd be interested to see if it works for anyone else as I'd love to have that feature working on my PC. It may be time for an upgrade if it's just my mobo that doesn't like it.
EDIT: Just had a look around the web and I've come across a few German and Swedish forum posts from MK-85 users with the same issue.
Sorry, I thought you were talking about the Filco range.
I never tried the keyboard with the BIOS until now and mine shows the same issues as yours - Good spot m8!
I have contacted QPAD and hope to have a resolution soon - I'll keep you posted.
*EDIT*
Ultra fast response from QPAD:
So far I have not encountered this problem on MK-85 nor MK50 or MK80. No
support mails or no experience at all.
Could this be an isolated problem with your motherboard? Is there any
setting that puts USB to sleep mode?
I will google the problem a bit and return to you next week with what I
could find.
Best regards / Med Vänlig Hälsning
/Christer Körnbäck
QPAD®
Again, I'll keep you posted.
Ok, I've tried the keyboard with another X79 motherboard (also UEFI BIOS) and that presents the same issues.
I'll dig out an old skt775 that has a standard BIOS and see if it is just a UEFI thing or not.
Yeah same again. Damn - hope QPAD sort this asap. I'll post their reply up here to let everyone know.
I wouldn't worry about the mouse thing - many high end mouse don't (my Sensei has issues with UEFI). Try disabling/enabling legacy BIOS - sometimes helps.
The keyboard is however worrying, hopefully we will get a resolution soon.
That's that not much of a problem anyway, I have spares and I don't ever go into the bios. It's just weird the problem wasn't spotted, or got swept under the rug. This time I don't think a motherboard bios update will fix it (already one for my mouse).
I can't get anywhere near the bios or if I have to hard reset my computer the "start windows as normal" option instead of repair. The back light does come on so something is happening.
