Hi,
After the success of the H7 Cooler Cryorig decided they wanted to work on making it perform even better and offer something a little different to other air coolers on the market.
Cryorig have teamed up with NZXT to allow the cooler to work along side the NZXT CAM software allowing you to control the lighting for the cooler with ease. You will be able to independently control the logo and base lighting of the heatsink through CAM software and mobile phone app.
The difference besides the addition of the Lumi Lighting System is an upgrade to four high performance heatpipes for added TDP capacity, a new QF120 LED 1600 RPM fan and also a reworked mounting system. With the upgraded heatpipe setup, the H7 Quad Lumi has increased heat dissipation performance by at least 15% over the H7 and now supports 160+ watt CPU’s. The new Quick Mount system will also provide support for LGA2011 v3 as well as continue support for LGA115x and AMD’s AM4 sockets. Supporting all latest offerings from Intel and AMD
Cryorig H7 Quad Lumi Single Tower Heatsink with Lumi RGB System @ £55.99 inc VAT https://www.overclockers.co.uk/cryo...-heatsink-with-lumi-rgb-system-hs-00r-cy.html
Socket Compatibility: 775 / 1150 / 1155 / 1156 / 1151/ AM2 / AM2+ / AM3 / FM1 / FM2/AM4, 3 Year Warranty, RGB Lighting, Powered by NZXT Cam Software, 160w TDP
The H7 Lumi is the first air cooler to have full RGB control. Cryorig have linked up with NZXT to use the Cam software to change the lighting as much as you would like and with ease.
<iframe width="560" height="315" src="https://www.youtube.com/embed/tPczz2i103g" frameborder="0" allowfullscreen></iframe>
Enhanced Efficiency with Hive Fin Technology
Featuring CRYORIG’s proprietary Hive Fin™ technology, the H7 Quad Lumi gains the benefit of faster hot air exhaust speeds and air turbulence reduction, so air passes through further and is expelled faster!
Optimized Heatpipes Placement Improves Heat Transfer
CRYORIG’s proprietary Convex-Align™ System is again featured in the H7 Quad Lumi, allowing for more heatpipes concentrated towards the hot spots on the CPU surface. This grants better heat transfer from the CPU Die to all heatpipes.
Advanced Dual Channel RGB System
The H7 Quad Lumi features the most advanced lighting system on any cooling product to date. The dual channel RGB system that allows for individual lighting effects and colors for the top logo and bottom under glow. Reactive effects can respond to system conditions such as temperature, audio and more.
Integrated RGB LED Control System Powered by CAM.
Inside each H7 Quad Lumi, houses a NZXT CAM controller module. With the additional controller the H7 Quad Lumi is capable of full software control. Color change, lighting effects and even Fan RPM and profile settings are all capable through CAM software and app.
Compact Performance Small yet Powerful
The CRYORIG H7 Quad Lumi much like the H7 is designed with compatibility in mind. Maintaining the original 145mm height the H7 Quad Lumi is made to fit almost all cases on the market. At the same time it’s 160watt TDP thermal design makes it one of the best performance options for it’s miniature size.
Zero RAM Interference Unlimited RAM Compatibility
The H7 Quad Lumi features CRYORIG’s Zero Interference design, that keeps the full heatsink+fan compactly inside the CPU Keep Out Zone and away from the RAM slots. This means that users can choose whatever RAM they like and know for certain that it will work with the H7 Quad Lumi.
High Performance LED Fan with Quad Air Inlet™ Tech
The H7 Quad Lumi includes the new QF120 LED. Based on the original QF120 series the QF120 LED features white LED lighting as well as all of the existing features from the QF series including: Quad Air Inlet™ for added air intake, ultra wide PWM RPM range, integrated Acoustic Absorbers and HPLN™ bearing. It delivers a great balance of performance versus acoustics, while adding LED lighting
H7 QUAD LUMI Evolved and Improved
The H7 Quad Lumi is based on the award winning best seller H7. Besides adding the CAM powered RGB system, with the H7 Quad Lumi CRYORIG has added one additional high performance heatpipe as well as increased support enthusiast grade Intel LGA 2011v3. The H7 Quad Lumi is not only RGB capable but all around a more powerful Quad Heatpipe H7!
Heatsink Specification
- Dimension ( with fan ): L98 mm x W123 mm x H145 mm
- Weight ( with fan ): 713 g
- Weight ( without fan ): 585 g
- Heat pipes: 6mm heatpipe x 4 units
- Fin: T = 0.4 mm ; Gap = 2.2 mm
- Front Fin Pcs: 40 pcs
- Copper Base: C1100 Pure copper nickel plated
- RAM Tolerance Height: Limitless
- TDP: 160 W
Fan Specification:
- Dimension: L120 mm x W120 mm x H25.4 mm
- Weight: 128 g
- Rated Speed: 330 ~ 1600 RPM ±10 %
- Noise Level: 10 ~ 25 dBA
- Air Flow: 49 CFM
- Air Pressure: 1.65 mmH2O
- Ampere: 0.25 A
Only £55.99 inc VAT.
ORDER NOW
- TDP: 160 W
Fan Specification:
- Weight: 128 g
- Air Flow: 49 CFM
- Ampere: 0.25 A
ORDER NOW
