- 27 Apr 2021
Hello,
I recently bought a new computer system (excluding a graphics card, because, you know...). I decided to go with an ITX build but everything went in and connected up smoothly.
Except for the fans.
I bought a MSI montherboard "MSI MEG Z590I UNIFY mITX" (not available on overclockers) and a "MSI MAG CORELIQUID 240R" CPU liquid cooler. For the case fans I bought three "In-Win Polaris Aluminium RGB Fan".
The montherboard has a JRAINBOW connection and the CPU cooler connects to that and works correctly, but it turns out that the fans use the other type of RGB and I cannot get their lights working
From what I understand I have two options:
1) Buy a RGB controller board
2) Buy new JRAINBOW compatible fans
I'd prefer option 1 as it would be a little cheaper, but I am not sure what I am supposed to get. Equally I am unsure if things will be compatibile and I am guessing I'd get a better RGB experiance if everything was running off the motherboard RAINBOW connection.
Therefore I would really appreasiate some insite from others.
* What controller should I get
* Or, can you recommend a fan with the right RGB so I don't make the same mistake again
Thank you for the help.
