rgb help pls
10 Sep 2008
Uk
i wonder if someone can point me in the right direction.. my son has an a320m-k board.. and has just been given a corsair delta spec case that has RGB fans with it... what's the best controller to be able to use the RGB fans?
many thx in advance :)
If you only want to control the RGB, then the Corsair Lighting node Pro will do it all, however if you also want RPM control then the Corsair Commander would be needed. Both options require a spare USB header on the motherboard, and despite a few people here claiming the Icue software is naff I quite like it :)
ahh .. would nothing like this work ( https://www.overclockers.co.uk/akasa-vegas-rgb-controller-card-cc-009-ak.html ) just to connect the fans too?
The case if it came with the fans, should have some sort of mini controller with it, usually a tiny 3 button thing that controls speed of the LEDs, colour and mode, like this: https://imgur.com/geADlWf if it didnt come with that, shop around, you can pick that unit up very cheap.
As for the fan side of things, just plug them into any PWM header or a PWM splitter etc.
