RGB Help
3 Apr 2020
Hey All!
So have a Corsair Spec Delta Case that came with 3x RGB Fans that are chained and connect to a 4pin RGB header. Issue is the Asrock Z170 ProS board I was planning on using doesn't have a 4pin or 3pin header. Ive looked for a 4pin RGB Controller that may then plug into the reset button but cant find one.
Any Advice guys??
Have a look at this:
My basket at Overclockers UK:
Total: £75.64 (includes shipping: £8.70)​
I think this should work BUT I'm not 100% certain. I have a similar setup but with 3x Corsair LL120 fans. Your fans RGB leads go into the lighting node pro & the pro goes into the fan hub. Fan hub plugs into a USB2 header on your board. You might only need the fan hub if you want to control all 3 fans with the splitter instead of the lighting node pro. I'd buy the fan hub first & see if that works on its own. Trouble is Corsair give you 'quick start guides', which are not much help in finding out what you want to achieve.
