- 27 Oct 2024
- United Kingdom
I am using 2 identical AOC Q27G3XM monitors on Windows 11 set up as dual monitors. Both using DP connection.
Monitor 1 is my main monitor with the taskbar etc.
I notced yesterday that in NVIDIA control panel under "Change Resolution" Monitor 1 only has the option of YCbCr422 and not RGB.
If i tab onto Monitor 2 it has the choice of RGB, YCbCr422 and YCbCr444
Both monitor settings are exactly the same and also the same in windows settings.
I have no clue why?
I have no clue why?
