Rice in vents - help!
20 Oct 2002
UK
Looking for some advice here please guys:
I got married a few weeks ago and in keeping with tradition my car was set upon by various family members who put confetti, toilet paper and rice all over the interior, in every single crevice and cubby hole and shaving foam on the glass (none on the paint fortunately as I'd not have been too happy about that!)
i cleared out the car once i got home and gave it a good wash and hoover... but some rice found its way into the vents and remains there... every time i go around a roundabout with any speed i hear it sliding around and when i turn the fans on full blast to clear the screen the same thing happens as it all jumps about inside.
The car isn't anything fancy - Civic EP2... but the angle of the windscreen makes it impossible to get a hoover nozzle to the front vents.
I'm just wondering if anyone has any suggestions, as the last thing i want is the rice to take on moisture in the coming months and stick / clog the system, or got mouldy and stink out the car for ever more. I need to try and shift it whilst its still dry.
Any ideas as to what i could do?
- Get a wire coathangar, unravel it.
- Put duct tape over one end with the sticky side facing outwards.
- Take a fast corner then stop somewhere so all the rice is on one side.
- Shove coathangar into vent, try and get rice grains to attach to sticky tape.
- Fling poo at relatives' living room windows.
Kill your relatives.
My brother was really put out when I told him not to shaving foam our car, that my parents had kindly given us, on our wedding day.
What the hell kind of tradition is this.
Nobody should mess with another man's car in this fashion.
This may work ;)
But only if the tube is thin enough to fit down through the air vents !!!!!
http://www.ebay.co.uk/itm/32mm-SPEC...Vacuum_Cleaner_Bags_Parts&hash=item19c17c4819
Thanks guys, seems obvious now that I think about it. I'll find the nearest roundabout to my house and crawl home afterwards, then hoover it off the passenger side vent - in theory!
I've learned something new today, I had no idea that this was traditional to do to cars in some places. I've heard of brides/grooms getting blackened as part of hen/stag parties but never this.
You've never seen it where cars get tin cans attached to the back and 'Just Married' put on the rear window? It was that, just a bit more full on... they did try and do something which didn't last, but the rice slid off the plastic dashboard down into the front vent.
