go on the oculus reddit wiki, it has a list.Which USB extension cables have people found work best with the rift sensors? I'm looking to wall mount my sensors
Thanks will check those out.
Sorry another question, will the rift work using a DVI to HDMI adpater?
If you can, it's best to use a HDMI port. A DVI or DP to HDMI adapter *may* work (I had to use a DP to HDMI adapter with my 295X2) but it's not recommended in general. And as such you'd use a HDMI to HDMI extension cable (and again, no guarantees these will work either).
