Rig for gaming and virtualisation
27 Mar 2015
Hi there folks,
Been a looooong time since I put a rig together and would welcome your thoughts on the basket below... Also first shot at water cooling which should be entertaining; then again may have this built by someone else :D (especially as it's essentially an extension of the rather nice http://www.overclockers.co.uk/showproduct.php?prodid=FS-454-OE)
It's a rig for some casual gaming and as the main workhorse for some serious virtualisation malarkey. Hence the 32GB memory. Quiet and cool is the aim of the water loop and I was thinking 240 rad at the top, 120 at the back with the 200 pre installed fan pulling air in. The D5 res / pump mounted at the side plate at the back of the Evolv front fan. I know the rads are a little thick but think they should work in positions due to offsets in the top. Might not need the 120... Thoughts?
Couplings and fittings are a little bit of black art tbh though I was thinking acrylic... Would I also need a separate flex drain point?
m2 drive for system and system images and the 850 Pros striped for apps and storage speed (it's backed by a chunky NAS).
The GTX 980 Hydro Copper is going to be driving a Samsung SE790C @ 3440 x 1440. No need to SLI as I'll wait a few months and get a Titan X (when I need to clear more of my top line ;))
Would prefer the EVGA X99 Micro (Socket 2011) Micro ATX DDR4 Motherboard I think though it shows out of stock at the mo.
All thoughts welcome
YOUR BASKET
1 x EVGA GeForce GTX 980 Hydro Copper 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-2989-KR) £649.99
1 x Corsair Dominator Platinum 32GB (4x8GB) DDR4 PC4-21300C16 2666MHz Quad Channel Kit (CMD32GX4M4A2666C16) £479.99
2 x Samsung 1TB SSD 850 PRO SATA 6Gbps 3D NAND Solid State Drive (MZ-7KE1T0BW) £474.98 (£949.96)
1 x Intel 5930K 3.50GHz (Haswell-E) Socket LGA2011-V3 Processor - OEM (CM8064801548338) £464.99
1 x Asrock X99M Killer Intel X99 (Socket 2011) DDR4 Micro ATX Motherboard £184.99
1 x Samsung 850 EVO Series M.2 500GB SATA 6Gbps Solid State Drive (MZ-N5E500BW) £172.99
1 x SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - White £165.95
1 x XSPC D5 Photon 170 Reservoir/Pump Combo £129.95
1 x XSPC RayStorm CPU WaterBlock (Intel) Copper £104.99
1 x Phanteks Enthoo Evolv Micro ATX Case - White £89.99
1 x XSPC AX240 Dual Fan Radiator - White £74.95
1 x Asus PCE-AC68 802.11ac Dual-band Wireless AC1900 PCI-E Adaptor £59.99
1 x XSPC AX120 Single Fan Radiator - White £56.98
1 x PrimoChill Revolver Compression Fitting Acrylic Tube 13/10mm grooves 10 - white £49.99
2 x PrimoChill 13/10mm Acrylic Tube 60cm 4-Pack - Clear £15.95 (£31.90)
2 x Mayhems Pastel - Ice White Coolant 1L £14.99 (£29.98)
3 x Noiseblocker NB-eLoop Fan B12-3 - 120mm (1900rpm) £10.2 (£30.60)
1 x Arctic Silver 5 Thermal Compound (3.5g) £8.99
3 x Silverstone SST-FF123W magnetic dust filters, white - 120mm £4.99 (£14.97)
1 x Mayhems Fine Silver Kill Coil £4.5
1 x Lamptron 5mm Ultra bright LED With Cable - white £1.99
Total : £3,776.33 (includes shipping : £14.75).
Overclockers will build a system for you, post in customer service. Firstly get the retail cpu as it has 3 years warranty over 1 year for OEM.
Gtx 980 for casual gaming if at 1080p is overkill.
1000w psu not needed for a single gpu unless you plan to go SLI
Thanks mickyflinn. When I say causal it's more of a case of 'when work and baby will allow I'll cane it at preferably high res with 60fps stable'.
The 1000W power is probably a little overkill atm but it's for a year or so down the line when I eventually go to SLI.
Nice point towards ocuk for the build, ta. Heading towards end of financial year so it'll be a good bet at this point :)
