rig problems new dxdiag log
13 Jan 2008
other threads to narrow down my problem
http://forums.overclockers.co.uk/showthread.php?t=17828640
http://forums.overclockers.co.uk/showthread.php?t=17830039
http://forums.overclockers.co.uk/showthread.php?t=17828740
can someone looke at this log file
i was told i might find the solution to my rig proble in here
System Information
Time of this report: 1/18/2008, 13:37:59
Machine name: KEV
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: X38-DQ6
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz (4 CPUs)
Memory: 2046MB RAM
Page File: 317MB used, 3620MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 8800 GTS
Manufacturer: NVIDIA
Chip type: GeForce 8800 GTS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0193&SUBSYS_22521682&REV_A2
Display Memory: 320.0 MB
Current Mode: 2560 x 1600 (16 bit) (60Hz)
Monitor: Dell 3007WFP
Monitor Max Res: 2560,1600
Driver Name: nv4_disp.dll
Driver Version: 6.14.0011.6921 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 12/5/2007 01:41:00, 5773568 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 12/5/2007 01:41:00, 7435392 bytes
Device Identifier: {D7B71E3E-42D3-11CF-3B6E-590203C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0193
SubSys ID: 0x22521682
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: HID Keyboard Hot Keys
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0E6A, 0x6001
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2936
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/23/2001 12:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ Cherry GmbH USB Keyboard
| Vendor/Product ID: 0x046A, 0x0001
| Matching Device ID: hid\vid_046a&pid_0001
| Service: kbdhid
| Driver: kbdhid.sys, 8/3/2004 20:58:36, 14848 bytes
| Driver: kbdclass.sys, 8/3/2004 20:58:34, 24576 bytes
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ Microsoft USB Wheel Mouse Optical
| Vendor/Product ID: 0x045E, 0x0040
| Matching Device ID: hid\vid_045e&pid_0040
| Service: mouhid
| Driver: mouclass.sys, 8/3/2004 23:05:44, 23040 bytes
| Driver: mouhid.sys, 8/23/2001 12:00:00, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 371.6 GB
Total Space: 381.5 GB
File System: NTFS
Model: SAMSUNG HD401LJ
Drive: F:
Free Space: 123.5 GB
Total Space: 476.9 GB
File System: NTFS
Model: WDC WD5000AAKS-00TMA0
System Devices
Name: Intel(R) X38 Express Chipset PCI Express Root Port - 29E9
Device ID: PCI\VEN_8086&DEV_29E9&SUBSYS_00000000&REV_01\3&13C0B0C5&0&30
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
Name: Intel(R) X38 Express Chipset PCI Express Root Port - 29E1
Device ID: PCI\VEN_8086&DEV_29E1&SUBSYS_00000000&REV_01\3&13C0B0C5&0&08
Name: Intel(R) X38 Express Chipset Processor to I/O Controller - 29E0
Device ID: PCI\VEN_8086&DEV_29E0&SUBSYS_00000000&REV_01\3&13C0B0C5&0&00
Driver: n/a
Name: Intel(R) ICH9 Family PCI Express Root Port 6 - 294A
Device ID: PCI\VEN_8086&DEV_294A&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E5
Name: Intel(R) ICH9 Family PCI Express Root Port 5 - 2948
Device ID: PCI\VEN_8086&DEV_2948&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E4
Name: Intel(R) ICH9 Family PCI Express Root Port 4 - 2946
Device ID: PCI\VEN_8086&DEV_2946&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E3
Name: Intel(R) ICH9 Family PCI Express Root Port 1 - 2940
Device ID: PCI\VEN_8086&DEV_2940&SUBSYS_00000000&REV_02\3&13C0B0C5&0&E0
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_50061458&REV_02\3&13C0B0C5&0&D7
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/3/2004 22:56:44, 7168 bytes
Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_50061458&REV_02\3&13C0B0C5&0&EF
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2939
Device ID: PCI\VEN_8086&DEV_2939&SUBSYS_50041458&REV_02\3&13C0B0C5&0&D2
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2938
Device ID: PCI\VEN_8086&DEV_2938&SUBSYS_50041458&REV_02\3&13C0B0C5&0&D1
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2937
Device ID: PCI\VEN_8086&DEV_2937&SUBSYS_50041458&REV_02\3&13C0B0C5&0&D0
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_50041458&REV_02\3&13C0B0C5&0&EA
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_50041458&REV_02\3&13C0B0C5&0&E9
Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_50041458&REV_02\3&13C0B0C5&0&E8
Name: Intel(R) ICH9 Family SMBus Controller - 2930
Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_50011458&REV_02\3&13C0B0C5&0&FB
Driver: n/a
Name: Intel(R) ICH9 2 port Serial ATA Storage Controller 2 - 2926
Device ID: PCI\VEN_8086&DEV_2926&SUBSYS_B0021458&REV_02\3&13C0B0C5&0&FD
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 13:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
Name: Intel(R) ICH9 4 port Serial ATA Storage Controller 1 - 2920
Device ID: PCI\VEN_8086&DEV_2920&SUBSYS_B0021458&REV_02\3&13C0B0C5&0&FA
Name: Intel(R) ICH9R LPC Interface Controller - 2916
Device ID: PCI\VEN_8086&DEV_2916&SUBSYS_00000000&REV_02\3&13C0B0C5&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_92\3&13C0B0C5&0&F0
Name: GIGABYTE GBB36X Controller
Device ID: PCI\VEN_197B&DEV_2363&SUBSYS_B0001458&REV_02\4&24C54F4F&0&00E3
Driver: C:\WINDOWS\system32\DRIVERS\jraid.sys, 1.17.0020.0003 (English), 6/13/2007 15:47:12, 48256 bytes
Name: Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC #2
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_E0001458&REV_01\4&CF4E44&0&00E5
Driver: C:\WINDOWS\system32\DRIVERS\Rtenicxp.sys, 5.684.1205.2007 (English), 12/5/2007 13:45:30, 104064 bytes
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_E0001458&REV_01\4&345CAFAF&0&00E4
Name: NVIDIA GeForce 8800 GTS
Device ID: PCI\VEN_10DE&DEV_0193&SUBSYS_22521682&REV_A2\4&17D528C6&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 7435392 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 5773568 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 155716 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 385024 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 1089536 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 6901760 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 8523776 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11132 (English), 12/5/2007 01:41:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 6549504 bytes
Driver: C:\WINDOWS\system32\nvdispsr.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 5611520 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 3420160 bytes
Driver: C:\WINDOWS\system32\nvgamesr.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 3334144 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmccssr.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 458752 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 1228800 bytes
Driver: C:\WINDOWS\system32\nvmoblsr.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 2854912 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 3710976 bytes
Driver: C:\WINDOWS\system32\nvvitvsr.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 3715072 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 2498560 bytes
Driver: C:\WINDOWS\system32\nvwssr.dll, 6.14.0011.6921 (English), 12/5/2007 01:41:00, 2519040 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 12/5/2007 01:41:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 12/5/2007 01:41:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 12/5/2007 01:41:00, 35328 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 12/5/2007 01:41:00, 35328 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8024&SUBSYS_10001458&REV_00\4&1ADD88A5&0&30F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/3/2004 21:10:10, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 21:10:08, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/3/2004 23:05:44, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/3/2004 23:05:44, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
part2 next post
part2
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:42 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:42 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:42 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:42 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 12:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 12:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:50 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:50 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:04 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:04 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:50 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 12:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:58 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 12:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:05:44 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:08:22 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 82432 bytes
system.dll: 1.01.4322.2407 English Final Retail 1/11/2008 21:03:42 1232896 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 12:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/3/2004 22:56:44 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 22:56:48 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:42 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:44 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:44 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:58 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:44 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:44 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:46 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:46 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:46 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:46 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:26 733696 bytes
quartz.dll: 6.05.2600.3243 English Final Retail 10/29/2007 22:43:03 1287680 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 09:52:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/3/2004 22:56:58 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/3/2004 22:56:58 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/3/2004 22:56:44 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/3/2004 22:56:44 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/3/2004 22:56:44 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/3/2004 22:56:44 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/3/2004 22:56:44 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/3/2004 22:56:58 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:46 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:05:44 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:58 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/3/2004 22:56:44 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:58 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:05:44 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/3/2004 22:56:48 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.3243
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.3243
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.3243
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.3243
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.3243
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.3243
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.3243
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.3243
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.3243
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.3243
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.3243
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.3243
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.3243
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.3243
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.3243
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.3243
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.3243
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.3243
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.3243
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.3243
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.3243
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.3243
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.3243
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.3243
Looking at your post here.
Pull up the task manager (either CTRL + ALT + DEL) ir click down low on taskbar >task manager and go to the perfomance tab.
This is prolly a software issue as other have said, and some screens of the actual problem may help.
That dxdiag tells us it all seems OK.
You also said "colorist m550v"...did you mean COLORSit?
Hmmm COLORSit Colors 600W £19.99......
They have always been stear cleer...see http://www.diy-street.com/forum/showthread.php?t=29248
yes that make but mine is 550 w
ok i have the perfomance tab open (now what?)
when i play my pc just stops ,ie the mouse does not move, sometimes bsod
i cant show the ghosting atm as i cant keep the poker softwere on long enough without it locking up to do a screen shot
formated 4 times and just loaded min drvers on raptor and tried 2 different poker sites
formated anohter hd 3 times loaded min stuff 2 different poker sites
yes that is the psu
Whats the CPU and memory usage at?
One like this isn't doing much.
Your PSU isn't top notch, but is the machine OK in every day use?
You need to max it out on something else and see if it falls over. (crashes)
Rig details for others...
GA-X38-DQ6 bois f7 (new) (not too sure what it came with but i have tried a few)
Q6600 go (new)
Akasa AK-925 Revo CPU Cooler (new)
corsair twin 2x2048-6400c4dhx ram (new) ( as recomended for the board by corsair) tested on memtest 1.60 for 20.5 hrs ,58 passes and no errors
320 8800 gts ( old)
Western Digital Raptor 74GB 10000RPM SATA 16MB (old)(windows )
400 gb Western Digital (old)
500 gb seagate (old)
3007 30" dell 2560x1600 (old)
creative live platinum 5.1 ( very old)
windows xp pro 32bit sp2 and all updates
antec 900 case
I wouldn't have thought for one minute that your PC lacked the CPU or resources ram wise to play poker..esp as you say others are doing it OK with 20 games open.
orthos or prime will stress it... see say here.
You have a nice system in fact...I'm just not sure on that PSU.
Mind you...I bet these poker sites have a lot of anti cheat stuff working.
yeah they do have anti cheat softwere as there are millions of£ played daily,,
will run them test later and over night
been playin 6-8 tables for 4 hrs had 1 bsod and 1 lock up
gee its bugging me
also been intuch with poker site ,, they say its my pc
