Method 1 for MAC users with TuneUp installations older than 1.5 (TuneUp only)
1.The uninstaller on your Mac is located under: Home Folder – Library – Logs – TuneUp Uninstaller. Click the icon to launch it.
2.Answer Yes to popup windows.
Method 2 for MAC users with TuneUp installations 1.5 and newer (TuneUp only)
1.The uninstaller on your Mac is located under: Home Folder – Library – Application Support – TuneUp_Uninstaller. Click the icon to launch it.
2.If you cannot find the patch or the patch doesn’t exist, try this other one: /Users/ Your_User_name/Library/ Application Support/ Tuneup_Support. Click the icon to launch it.
3.Answer Yes to popup windows.
Method 3 for Windows users. Remove it via DOS (TuneUp and TuneUp Utilities)
1.Click Start.
2.In the Search field (Windows 7) or Run…(Windows Vista) type cmd and press Enter.
3.On the black DOS window, type: cd C:\Program Files\utilities\TuneUp. The whole trick here is to know the exact folder where the software is installed. So, if you do not know it, you should click Start – Computer and browse among your Computer folders looking for such it.
4.Type unwise install.log and press Enter. This should start an automatic uninstallation procedure.
Method 4 for Windows users. Delete key by key and file by file (TuneUp and TuneUp Utilities)
1.Click Start.
2.In the Search field or Run.. type regedit and press Enter.
3.Locate this Windows registry folder on the left pane: HKEY_LOCAL_MACHINE\ SOFTWARE\Microsoft\ Windows\CurrentVersion\ Uninstall
4.On the right pane, locate the registry key which contains “TuneUp”.
5. look for the key UninstallString. Such a key points to the uninstallator. The log file is located on the same folder where the software resides.
6.Delete the key containing “TuneUp”.
7.Now, go to HKEY_CURRENT_USER\Software and HKEY_CURRENT_USER\Software. On such registry folders you should look for any subfolders containing the word “TuneUp” or the name of the company that produce the software (in our case the software compnay is called TuneUpMedia). Delete such registry subfolders containing TuneUp and TuneUpMedia
8.Exit Windows Registry.
9.Now go to Computer (Windows Explorer) and go to the folder where the software is installed.
10.Look for uninstall.log or setup.log or a file with .log extension.
11.Right-click it and open it with your Notepad.
12.Such a file contains a list of all files which have been automatically installed during the first installation. Delete them manually to uninstall TuneUp.
Method 5 for Windows users. Uninstall Old TuneUp version by installing newest Versions (TuneUp and TuneUp Utilities)
1.If you are running an old TuneUp version (such as TuneUp 2009) you have to know that suxh a version is buggy! So in order to fix it, you will have to update it with the new one. Go to Tuneup website and install the newest free version.
2.Try to uninstall the software again via Windows Install/Uninstall tool.
