Right click resize images in vista
5 Aug 2006
i used to use a power toy in xp to be able to right click on a picture and resize it there and then on the spot.
anything like this for vista? :(
ta
alec
Cool. not as good as the power toy i used but no far off either. will do anyway! thanks a lot bud :)
ta
alec
*edit*
lol
TheVoice said:
Yep I use VSO, works pretty well. Not as slick as the old XP one but good enough.
exactly what i was trying to say :p didnt see yer post there
That VSO thing is great, been looking for something like this for Vista.
It's better than the XP one as you can pick quality, file type etc.
Nice find :p
the quality was poor in the powertoy
use the tool 'shrink it' it's on the msfn forums, google will probably find it, its a small tool that you drag the files onto, not a right click menu though..
will stick with VFO but i shall download and keep in the store for future refrence :) ta
alec
