right, finally gunna order
22 Mar 2009
Cornwall
ok, gunna order my mobo and gfx card today.
decided on the HD6850, but looking at the suppliers, its not a huge amount more for a HD6870, is it worth the extra £40-£50?
will i be good to run it on a AsRock 890FX DELUXE3 mobo with my current cpu/ram combo without too much bottleneck?
i can only order from one place (do it through work) and these are the prices :
HD6850 - £110
HD6870 - £150
HD5870 £220
so twice the price :(
or alternativly i can get a GTX460 for the £120-£150 mark depending on brand
dont really want to overclock, just really want to get the best value for money really.
also, the GTX460 2GB is nearly £10 cheaper then the HD6870, would that be the best all rounder?
better than a GTX460 2GB for £141?
That's tempting but there's not much you can't max out with 1GB. It only really becomes a limiting factor when you're trying to play at absurd resolutions (higher than 1920x1200) with AA... or GTA4 :p
I recently switched from 5870 to GTX570 SLI (yet to update sig) and I'm glad to be rid of the CCC; Nvidia's drivers are far superior IMO.
The GTX460 seems slower at stock though. As JD said, if you o/c it will should end up the faster card, even faster than the 6870.
ok, last question, which one :
VX6850 1GBD5-DH - £110
Key Features:
* Product Description: VTX3D Radeon HD6850 1GB DDR5 256Bit
* Interface Type: PCI-E
* Chipset: Radeon HD 6850
* Memory size: 1024MB
* Core Clock Speed: 775Mhz
* Memory Clock Speed: 4000Mhz
* Stream Processors: 800
* DX Supported: DX11
* Display: Display Port / HDMI / Dual DVI
* Hyper Memory Support: No
* Cooling: Fan
* PSU Requirements: 500Watt
* Multi Card Support: Yes
or
VX6850 1GBD5-DHX - £114
Key Features:
* Product Description: VTX3D Radeon HD6850 1GB DDR5 256Bit X Edition
* Core Clock Speed: 800Mhz
* Memory Clock Speed: 4200Mhz
* Cooling: Fan
Drivers seem to be a subjective thing. The new CCC (mind you I have never seen the old CCC!) is as nice as the nVidia control panel IMO.
I have had both nVidia and AMD in the past few months (460 GTX vs 6950@70) and at this point in time I prefer the AMD ones because they just work and I didn’t have to wait a month to get a fix for Bad Company 2 and that is not including the problems I had with the supreme commander games.
Regarding the 6870 vs 6850 vs 460 they are all pretty much the same. If you are not overclocking get the fastest one at stock and that is the 6870 which at £150 is fantastic value seeing as it has 470 speeds.
ok, not overclocked a gfx card before (my mate did one back in like 2000) is it easy to do and safe? i dont like the idea of flashing bios incase it messes up and i have £110-£150 of dead card.
In this thread you said you could get a Gigabyte HD6850 1GB too:
http://forums.overclockers.co.uk/showthread.php?p=18249346#post18249346
Gigabyte has a better warranty in the UK when compared to VTX AFAIK.
yeh i can get the gigabyte GV-R685D5-1GD for the £110, but the cooling system doesnt look as nice/good
spec wise though :
Series: Radeon HD 6000 series
Core Clock: 775MHz
Memory Clock: 4000 MHz
Memory Type: GDDR5
D-sub: No
DVI: Yes
Memory Size: 1 GB
TV-OUT: No
the VTX3D comes with 2 year return to base warrenty, the gigabyte has 3 year return to manufacturer warrenty
