Just got a set of riing trio fans today but im short on a usb 2.0 header on the mobo.
I noticed the riing trio kit comes with a usb 2.0 header plug that splits into two usb micro plugs , i have nzxt hue + which uses micro usb on the controller as does the riing trio controller.
Could i use this plug that splits into two micro usbs to connect up both my hue+ and riing trio? Or will it mess things up, i do have the nzxt internal hub at hand but if i can get away with using it i will as its less clutter in my case..
