Riser Cables
18 Oct 2002
Leicestershire
Just replaced my 3080FE with a 5070 I picked up cheap, put it in my main rig, no output, needed my PC for stuff so put the 3080FE back in and tested the 5070 in my open air test rig, worked fine..
Took me about 2 hours of messing with PSU cables and stuff to realise I'm using a board that supports PCIe x5, and a GPU that supports x5, and a bloody x4 riser cable...
Dropped into the BIOS, set the mode from Auto to x4, surprise surprise, everything now works...
So, as I'm using the SSUPD Meshiliscious, what cables do people recommend to replace the x4 version, as I'd rather just swap the cable than have to remember to set the mode again if I ever default the BIOS for whatever reason...
Linkup v3 double reverse 14cm if you’re using itx. Alternatively meshroom had gen5 risers available on their store. I got a 40cm version for ATX but never got round to testing it.
Edit: also what board is it. Some have jumper pins or switches that make it auto gen3/4 to prevent this sort of thing.
Asus Z790i Lightning, I'll have a dig through the manual, wasn't aware some boards had jumpers to solve the issue, cheaper than a new riser...
I had that board, it's on that little card where you plug in motherboard headers, the switch has 3 positions.
I am running the Meshlicious as well. I have left mine at X4, not much difference in performance. I also have my own little check list of the things to do after any BIOS updates, which includes the X4 setting for the GPU.
Yeah, I could do the same, but, for what I've already spent this month on stuff I don't need, what's adding a bit more for a cable that I'll never see, and forget exists as soon as I stick the sides back on the case :D
I had the same issue when i upgraded, have a older Meshlicious case with a 5070ti. my Mobo supports x4 but the cable is only x3. Had to change the setting in the Bios to x3 to get it to boot.
i looked into getting a x4 cable. you can buy one on OCUK but at £86.99 for a fing cable! its ridiculous especially for and extra 2 fps! just make sure the cable to have is x16 and you should be fine.
its nuts that it's probably not much more expensive to go buy a brand new SFF case than to pay for just a cable that should be £35 at the most!
or you can buy the Meshroom D which will remove the need for the riser. Shame SSUPD has no stock anywhere. hoping they will have new models in the near future.
Well yeah you can get New SFF case for less than £86. Not SSUPD ones with riser cables.
Nah, I do like this Meshy tbh, think my next case will be a good few years away yet...
No, still clearing out all of my post move junk that I don't have space for any more, once that's done, I've got a proper cable for my PSU-GPU to go in there, will do the riser at the same time as its been about 18 months I think since the last time I stripped the machine down, cleaned, and rebuilt it.
