Rivatuner problem
10 Apr 2004
Weston-Super-Mare
Hi, I'm having a problem with the latest version of rivatuner,,when i try to run it, it come up with the following error.. "cannot load rivatuner32.sys driver, please ensure that this file exits in rivatuner folder and your user account has adminstarative rights"
The 32.sys driver file is in the rivatuner folder,, have tried uninstall and reinstall but it stll say's the samething,, any advice as i dont know what to do?? and really need rivatuner running so i can adjust the fan speed on my ultra..
Thanks in-advance...
System requirements:
* Windows 98 (updated MFC libraries required), Windows 98 SE, Windows ME, Windows 2000, Windows 2003 Server x32, Windows XP x32, Windows XP x64 edition or Vista x32 (limited feature set available)
Vista 64 is not listed there, maybe thats the problem ?
I had to disable the signed driver checks in command promt:
bcdedit /set loadoptions DDISABLE_INTEGRITY_CHECKS
Then run as admin.
The Vista 64-BIT update, recently installed, scuppered the driver signing workaround and it looks like RivaTuner won't be able to afford the MS cost to aquire the permissions -
http://forums.guru3d.com/showthread.php?t=234059
Ray
PS...it's the F8 (disable driver signing), during every boot routine, if we use RT 'till a new tweak is found
