- 14 May 2012
I've been running @
4.5ghz (125blk 36x) on my 3820 for a while now, plenty of time to stabilize my loop (other than my res leaking).
Getting Idle temps of 30c and load temps around 55c running @ 1.3v.
It bluescreens on boot at 37x @1.3v & 1.35v (however that could be my RAM causing that as it's only 1866 running at 2000 (@36x) and faster @ 37x
Timings are 9, 10, 9, 27, CR2, which is rock steady @ 2000mhz.
VTT - 1.1v
VCCSA - 1.1v
DIMM's @ 1.65v
Most settings are as the X79 guide.
Should I drop the RAM frequency, and try to get it back up using the BLK & multiplier? Or is the voltage not high enough?
It's Corsair Dominator CMP16GX3M4X1866C9 RAM.
VTT - 1.1v
VCCSA - 1.1v
DIMM's @ 1.65v
