If i have to RMA my 7900GT do i need the original packaging? I'm not 100% sure i'll need to RMA it at all yet. The reason i'm worried is that when i try to use the overclocking feature via coolbits i start to get multi-coloured speckles (much like dead pixels on a tft) on my desktop during it followed by the machine locking up.
I threw out the box a while back and am worried that what i described above is a sign of a fault yet to be seen in normal use and that they wont accept it for RMA if i do eventually have to return it. I still have all the bits and pieces and the OC receipt though.
I'd say give it a while and see if all is stable at stock in games and windows. You can try your luck and RMA them as faulty, the worst that can happen is they'll be sent back to you as ok. then you could try and sell them and get abother pair, should be able to get what u paid for them back...
