thanks for the tip i will do m8Sean_UK said:7950 better card yes, you should be very happy. Watch the temps with that new gfx card though.![]()
i havent recieved it yet and only just got the email so hopefully if i get it tommorrow ill ring them up straight away and try sneek an 8800 out of them :dfobose said:You should have complained and requested they swaped your second 7800 for a 7900 as you bought 2 to run in Sli and now you cant![]()
