RMAing 670, need replacement
12 May 2007
Bristol
I need to RMA my MSI 670 PE (from the day I got it, it's only stable if it's underclocked by 150Mhz), but I can't be without my PC for however long it takes to get sorted.
I was thinking of just buying a new card and then selling my replacement when it arrives, but I'm not sure if there is anything in the £200-300 price bracket worthwhile.
Anyone have a suggestion?
you might not get a 670 back, see what they send/offer you first. It might be worth the wait!
I'd do that, but my problem is that I just can't go without my PC for 'up to 28 days'.
(I really should have sent it back when I first got it, but after I was given the RMA number, work became hectic and I just forgot)
Looks like I may have to consider the 290/x then.
